Just finished the one more install of MS3X.
Inline 6
1200cc EV14 High ohm injectors
Wasted spark
Éngine started after first but I have very strange issue that I never seen before.
Both CLT and IAT jumps like crazy between current temperature and over 200 Celisus.
CLT jusmps allmost every 2 seconds and IAT about every 20 sec.
I tryed to:
Put them in free air
new sensors
new wiring
ground to different places
Nothing helps!
When I remove the connector från the sensor CLT shows stabil 81C and IAT 21C
Any ides?
Thanks!
MS3X CLT and IAT problem!
Mercedes 300E Turbo MS3X 1150hp
http://www.turbobandit.com
http://www.youtube.com/user/PUMPISH
https://www.facebook.com/pages/Turboban ... 24?fref=ts
Re: MS3X CLT and IAT problem!
Hi
Can you test with a Stim?
Frank
Frank
Yes same issue with a stim!franksidebike wrote:Hi
Frank
We even tryed:
install new ms3 card and stil the same issue
convert v3.0 card to ms1 extra and then it works
But v3.0 card together with ms3 card still the same problem
What voltage do you measure on the CLT and IAT input pins?
Matt Cramer wrote:What voltage do you measure on the CLT and IAT input pins?
I found out:
If I reflash ms3x and reinstall Tuner studio and then use USB imput then it works just fine!
As soon I use DB9 I get errors and CLT and IAT start jump like crazy again.
So if I switch back to USB i stil have the same issue!
I must reflash both ms3x and reinstall Tunerstudio to get rid of the problem and only use USB.
As soon I use DB9 i infect both ms3x and tunerstudio and no ide why!
Is this a built in DB9 on the laptop, or a USB to DB9 adapter? If so, what sort of adapter?
