Sensor calibration issue with MS1
TomppaHe
Post by TomppaHe »
Hello,
I'm really having trouble with the temperature sensors in TunerStudio. I have searched solutions for two days but no success. I'm just not getting the temp sensors show right in TunerStudio.
I'm running MS1 2.2 board with MSExtra code and I have the latest v2.6.01 registered version of TunerStudio.
I have some Bosch and BAE sensors. I have made the inc-files using Easytherm and when I use Megatune they show correct. With Tunerstudio they don't. I have copied the inc-files (airdenfactor, matfactor, thermfactor) to C:\Program Files\EFIAnalytics\TunerStudioMS\inc and to C:\Users\T&T\Documents\TunerStudioProjects\Streetmachine\inc (Streetmachine being my project name). These were two different advices I found around message boards but no help for me. Also tried couple of other places for them but can't remember anymore.
WHAT am I missing?? In Megatune I get MAT=CLT=18C cold in garage while Tunerstudio shows 16 and 26C.
Also spent couple of hours looking for why don't I see thermistor table calibration tool that somebody suggested. It's not working with MS1 as I finally learned. I'm quite frustrated already so I really hope I would get some help here though I'm also bit shamed that I need to ask what feels such a beginner question.
regards, Tomi
LT401Vette
Re: Sensor calibration issue with MS1
Post by LT401Vette »
The proper plaec to put the inc files from EasyTherm is:
[YourTunerStudioProjectFolder]/inc/
Which I looks to be:
It should be that simple if they are the correct inc files.
Can you post the inc files you are using?
Also when Tunerstudio shows 16 and 26C, if you change a gauge to CLT ADC and MAT ADC, when are the values being displayed for the raw ADCs?
TomppaHe
Post by TomppaHe »
By you pointing me in right way I was able to figure that the ADC values match with the temperature readings I get according to .inc file being used.
The problem was that Easytherm actually didn't modify the files because I didn't run it as admin. d*** Windows 7!! Somehow it did change the modified date of the file but not the content!
What I still can't figure out what .inc files Megatune was using as it was showing the right temps. All .incs' I could find had the same numbers. One of my major problems is that I'm not frequently working with Megasquirt and these sw's. When I have half year break I can't remember what was working last time... and so on.
Thanks very much. I think I'm ok for now. Now I get to try the warmup autotune which I hope will help my issues with cold engine.
Tomi
