Programmable output status
Maybe I just missed it, but is there a way to configure an indicator to show the status of a programmed output?
Re: Programmable output status
Indicators are easy to create/configure in TS. Just right click on your TS screen and select Designer Mode
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
I know how to add gauges and indicators, but I do not see any options that would correlate with the programmed output. It is using Injector G and it changes the intake manifold from long runner to short runner. I used to be able to hear the difference when N/A, but now that it is turbocharged, I no longer hear the change in resonance.
Add an indicator for the raw i/o port itself (e.g. PORTA6)
Ref: http://www.msextra.com/doc/ms3/hardware.html#pins
