tunerstudio on mac problem
Hi everyone,
I'm trying for a couple weeks to run tunerstudio on my mac with no good results. On my windows laptop everything is working fine with great tuning results.
I'm using the same usb to serial adapter which is a Lindy (prolific) and works fine on the windows laptop.
Now I've installed tunerstudio on my mac Ms v2.6.01 (recently updated) and installed the PL2303_MacOSX_v1.5.1 drivers on osx 10.9.4 (first tried with no drivers and later with 3 different prolific drivers)
When I open up tunerstudio, the settings and data rate options are greyed out. I can't load a project or msq file. I've copied my project from the windows laptop with the same negative result.
When I try to open my project the progress bar at the bottom freezes and nothing happens.
any info would be helpful
Re: tunerstudio on mac problem
Those would be greyed out until a project is open, so it is likely there is an error occurring during project open, so it is never actually getting opened all the way.When I try to open my project the progress bar at the bottom freezes and nothing happens.
My 1st guess would be failure to load the appropriate RXTX driver.
Can you post / send a TunerStudioAppDebug.txt?
Also, can you try downloading the tar.gz linux build. Just extract it anywhere on your hard drive and double click the TunerStudioMS.jar to run it, so it it is any different.
thanks for helping me!
In the debug file there's a line ""could not initialize class gnu.io.RXTXCommDriver thrown while loading gnu.io.RXTXCommDriver"
So you're spot on!
I can't figure out how to install or config this RXTX the right way, tried many drivers with no luck
So you're spot on!
Yes, that is likely the trouble.
TunerStudio has RXTX drivers bundled with it, but for some reason on OS X if there are drivers installed to:
/Library/Java/Extensions/
They take precedence.
If you are not using RXTX for any other purpose, I would try deleting the file:
/Library/Java/Extensions/librxtxSerial.jnilib
Then it should find the librxtxSerial.jnilib that is bundled with TunerStudio.
Phil, that is indeed the problem, I spotted this a while back (10.8+??), and I've not had any issues with Mavericks aka 10.9 at all. I double checked my settings after seeing this post, because I too use Window XP on my laptop, and sync my files through Dropbox, and wanted to make sure I wasn't mistaken. The reason why my RXTX driver was added to the Java/Extensions was a legacy fix thing from running TunerStudio on the Mac from yesteryear.LT401Vette wrote:...TunerStudio has RXTX drivers bundled with it, but for some reason on OS X if there are drivers installed to:
/Library/Java/Extensions/....They take precedence.
/Library/Java/Extensions/librxtxSerial.jnilib...
Mike
PS BTW, sometimes the odd bit of unsigned app is not installed, and it's easy to miss the dialog box when installing software off the web. You can check this by going into System Preferences>Security, and they be a comment about an outstanding "non trusted" apps etc, which you can then install after authorising.
Yamaha YZF1000 MSExtra 3.1
file is deleted, when I inserted the cable in the USB slot, this message pops up right away
The system extension'/Library/Extensions/osx-pl2303.kext' is not installed properly and can't be used. Please install again
When I try the command ls /dev/tty.* in the terminal, I can still see "/dev/tty.usbserial" and in the Aplle configuration USB menu I see
USB-Serial Controller D:
Productcode: 0x2303
Fabrikantcode: 0x067b (Prolific Technology, Inc.)
Versie: 4.00
Snelheid: Maximaal 12 Mb/sec
Fabrikant: Prolific Technology Inc.
Locatiecode: 0xfa143000 / 6
Beschikbare stroom (mA): 100
Vereiste stroom (mA): 100
Hope this may help to solve the problem
Productcode: 0x2303
Versie: 4.00
mrchoosy,
What does it say if you "get Info" on your .kext> Mike
PS Have you restarted the Mac?
PPS If you're OK using terminal type this in
Code: Select all
sudo kextload /System/Library/Extensions/osx-pl2303.kext/
mrchoosy,
You have edited your previous post, so what do you see in the System/Library/Extension...is the osx_pl2303.kext here like this?
Mike
Mike
I've tried the sudo and typed my password, when asked for. After that nothing happened
Here's the screenshot
Yep, it's there ; )
What does this mean? If you plug in the USB cable, there is no dialog box now or what?mrchoosy wrote:... After that nothing happened...
I saw this
mrchoosy
Your extension is in the wrong directory, looking at your attachment, it is definitely in the wrong place. You put it in this directory (this is my folder below with NO .kext) So delete this one and make sure one is added here
Mike
Mike
The file was indeed in the wrong but the exact same file was also in the right place. I' ve deleted the wrong one.
I think this looks better now.
Getting closer...
Getting closer...
OK mrchoosy,
If you Get Info on the OSX-pl2303.kext, the permission should be system wide now, or if you use Terminal and this again,
You should see some changes from before. Do you?
Mike
Code: Select all
ls /dev/tty.*
Mike
This is what I see now,pl2303-003014FA is added to the list tunerstudio is working right now!!! Thanks a lot!!!
Now setting up the port, gonna give it a try...
hallo mrchoosy
Mike
graag gedaan & goedenachtmrchoosy wrote:... tunerstudio is working right now!!! Thanks a lot!!!...
Mike
Not there yet
port test failed
Or do I need to restart first?
Thanks Mike
port test failed
Thanks Mike
Yes, mrchoosy, in my experience, it's always better to Restart, that way the extensions load correctly.
Mike
Mike
Hi Mike,
I still have the port failure after restart (not connected to the car's MS2)
Kristof
Kristof
