Good morning, I have been setting a MS3X up for a project the last couple days in my spare time, when yesterday out of the blue an error code popped up. This is the error. 1 Errors:
Error: expression error in ini entry for wueAnalRecommend, attribute: Minimum
Variable 'wue_lpg' used in expression, but not defined as OutputChannel or Setting Parameter
I'm using Ms Lite v 2.6.01
I'm searching for help and would greatly appreciate it.
tunerstudio errors:1 19 Warnings
Re: tunerstudio errors:1 19 Warnings
Version 2.6.01 does create this error with older versions of MS3 firmware. It is harmless, but annoying.
It is fixed in the beta 2.6.03 which should be getting promoted to stable quite soon.
http://www.efianalytics.com/TunerStudio/beta/
Thank you. That did it.
