I might be missing something; tried looking through the manuals, and forums, but no mention of this issue.
Under the Generic Sensor Input, I have defined Sensor01 as my fuel pressure, giving it the name "FuelPress" with the new Name Field. This user-defined name "FuelPress" does show up in the data Log Profile Editor pick list.
It does not show up under the Programmable On/Off Outputs picklist. I would like to turn on a warning lamp if fuel pressure drops below a setpoint.
Am running MS3-pre1.3.3beta2 build (LT1 opti-spark engine).
See attached screen shots and msq.
Programmable Output picklist not updating
Dave
1958 Cushman scooter Microsquirt'ed and turbo-ed
1994 Camaro MS3Pro and GPIO MShift
1996 Buick Roadmaster wagon, MS3Pro and uV3 TCU
Re: Programmable Output picklist not updating
It will be referred to as Sensor01. Generic Input sensors are referred to by their number, regardless what you name them.
Yes, when you change the field name, that will be used for the Data Log field names, but in the Programmable On/Off Outputs dialog, it is OutputChannels that are listed, not Datalog fields. The OutputChannel names are defined in the ini by the firmware developers and not altered, so would still be sensor01.
Got it. Thanks.
Dave
