licence issue any help?
edit: i have changed the wifi/bluetooth card as some issues with bt connection, i put the old one it works fine so does not like something to do with the fact the card has changed makes it think its a different computer.
licence
Re: licence
In most cases changing the wifi card won't make it think it is a different computer, but on windows XP that is possible.
Re: licence
it is xp. what can i do about it? as i was trying a different card to see if it would help with http://www.msextra.com/forums/viewtopic ... 22&t=55502
Re: licence
You can either switch back to the other card, or email support <at> efianalytics. com, we can remove an old activation that isn't being used.
