phil weird update bug
I'm sure its not you and probally my computer but anyway could use some help solving it. so when ts start it prompts me to update so I do ts then shuts down and I get a do you trust this program to change things I say yes then the ts say there is already a ts running do you want to bring it to fore ground I say yes then nothing happens... any thoughts?
Re: phil weird update bug
Some older versions of TS would get stuck updating. The easiest way to update is to download the installer again and run it. On some versions you could kill the extra java process and the update would continue.
MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next.
2333(103*70) Type 4 with DTM also sitting in living room just need exhaust.
