By coincidence we post on the same minute and i only notice now.
You are correct.
Now, how about the option to also have AFR2 working as second load and based on the same load as the VE2 and IGN2 ?
On my case i expand the tables, and at the same time i have use each load for the table were it works better, but than
i only have AFR1 table for this, and it is only based on one type of load, were it will only fit the load of one single table,
the other will be out of range in terms of load type.
Example:
IGNT1 + VE1 + AFR1 -Load = Alpha-N, SD, etc etc ( this is already possible including chose AFR load )
IGNT2 + VE2 + AFR2 -Load = Alpha-N, SD, etc etc
I don´t know if this is possible to do, or if is not appropriated, but for shore will help and make some sense, almost as ITB
but with separated tables for each types of load, including the AFR2 for more detail and same load as other (2º) tables.
James, tanks for your attention and patience with me.
How to enable AFR2 table ?
Re: How to enable AFR2 table ?
That would require firmware changes. Currently there are no plans to do that.RX-S7V7N wrote:Now, how about the option to also have AFR2 working as second load and based on the same load as the VE2 and IGN2 ?
Ok James, leave a note to remember this later, if by any chance in future you can do it, that will bejsmcortina wrote:That would require firmware changes. Currently there are no plans to do that.RX-S7V7N wrote:Now, how about the option to also have AFR2 working as second load and based on the same load as the VE2 and IGN2 ?
a nice feature to make Megasquirt better than it already is.
Once again, tanks for your support.
Regards
