hey guys,
can you tell my why i cant open any project with TS?
see my log:
TunerStudio 2.6.04 started on Tue Sep 09 10:19:30 CEST 2014
JRE 1.8.0_20, Windows 7 6.1, amd64
java.library.path=lib
TunerStudioMS.jar
Look:Metal, ClassName:'javax.swing.plaf.metal.MetalLookAndFeel'
Look:Nimbus, ClassName:'javax.swing.plaf.nimbus.NimbusLookAndFeel'
Look:CDE/Motif, ClassName:'com.sun.java.swing.plaf.motif.MotifLookAndFeel'
Look:Windows, ClassName:'com.sun.java.swing.plaf.windows.WindowsLookAndFeel'
Look:Windows Classic, ClassName:'com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel'
Setting Look & Feel to:javax.swing.plaf.metal.MetalLookAndFeel
09.09.14 10:19:31 :Debug: Command Non-VolatileBytes for F resolved to: x46 F
09.09.14 10:19:31 :Debug: Command Non-VolatileBytes for I resolved to: x49 I
09.09.14 10:19:31 :Debug: Command Non-VolatileBytes for f resolved to: x66 f
09.09.14 10:19:31 :Debug: App Name:TunerStudio, appEdition:MS
09.09.14 10:19:31 :Warning: Unable to set Main cluster for title:
09.09.14 10:19:33 :Debug: Time to retreive font name list: 5 ms.
09.09.14 10:19:33 :Error: Failed to load RXTX. Message:
C:\Program Files (x86)\EFIAnalytics\TunerStudioMS\lib\rxtxSerial.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
No check, last update check=Tue Sep 09 10:06:24 CEST 2014
MSmain: No check, last update check=Tue Sep 09 10:05:34 CEST 2014
MSad: No check, last update check=Tue Sep 09 10:05:38 CEST 2014
09.09.14 10:19:41 :Debug: Directory Changed:
Old:C:\Users\cmolnar\Documents
New:C:\Users\cmolnar\Dropbox\Projekt EFI\MegaSquirt\Chris 2.5-16V
09.09.14 10:20:02 :Debug: File Changed:
Old:null
New:C:\Users\cmolnar\Dropbox\Projekt EFI\MegaSquirt\Chris 2.5-16V\MyCar
09.09.14 10:20:02 :Debug: Opening project: C:\Users\cmolnar\Dropbox\Projekt EFI\MegaSquirt\Chris 2.5-16V\MyCar
09.09.14 10:20:02 :Debug: Reading translation file as plain text because: fast binary headers not found. probably not a fast binary file
09.09.14 10:20:02 :Debug: Filtered ConfigurationOptionGroup in 26ms.
09.09.14 10:20:02 :Info: Read file canPcVariables.ini: 0.0ms
09.09.14 10:20:02 :Info: Filtered ini: 0.0ms
09.09.14 10:20:02 :Info: Loading Trigger Wheels
09.09.14 10:20:02 :Info: Loaded All known ini sections
09.09.14 10:20:02 :Info: Parsed and validated ini "canPcVariables.ini" in : 21ms.
09.09.14 10:20:02 :Info: Read file mainController.ini: 7.0ms
09.09.14 10:20:02 :Info: Filtered ini: 3.0ms
09.09.14 10:20:02 :Debug: ini signature: MS2Extra SerialGS28
09.09.14 10:20:03 :Info: Set Write Blocks on = false
09.09.14 10:20:03 :Info: Loading Trigger Wheels
09.09.14 10:20:03 :Info: Loaded All known ini sections
09.09.14 10:20:03 :Info: Parsed and validated ini "mainController.ini" in : 112ms.
09.09.14 10:20:03 :Info: Read file ms2Supplement.ecu: 12.0ms
09.09.14 10:20:03 :Info: Filtered ini: 0.0ms
09.09.14 10:20:03 :Info: Parsed and validated ini "ms2Supplement.ecu" in : 26ms.
09.09.14 10:20:03 :Info: Read file ms2ExtraDefaultTools.ini: 0.0ms
09.09.14 10:20:03 :Info: Parsed and validated ini "ms2ExtraDefaultTools.ini" in : 7ms.
09.09.14 10:20:03 :Info: Read file ms2WueAnalyzeMaps.ecu: 0.0ms
09.09.14 10:20:03 :Info: Parsed and validated ini "ms2WueAnalyzeMaps.ecu" in : 5ms.
Exception in thread "ProjectOpenThread" java.lang.NoClassDefFoundError: Could not initialize class e.f
at z.f.<clinit>(Unknown Source)
at M.t.<init>(Unknown Source)
at M.t.a(Unknown Source)
at com.efiAnalytics.tunerStudio.fx.a(Unknown Source)
at com.efiAnalytics.tunerStudio.j.e(Unknown Source)
at com.efiAnalytics.tunerStudio.j.a(Unknown Source)
at com.efiAnalytics.tunerStudio.v.run(Unknown Source)
HELP cant open any project with TunerStudio
Re: HELP cant open any project with TunerStudio
Hi, I think you already worked through this with Brian.
In your log above I see amd64, thus it is a 64 bit JRE and currently needs a 32 bit JRE unless you swap out the RXTX driver for a 64 bit.
BTW: In the current alpha code, 64 bit is supported and JSSC is the default driver. So for the next major release 64bit vs 32 bit will be handed.
