Protocol Error
Re: Protocol Error
Hi, I have similar problem with the difference that i have Egt can box and lost the communication with the egt box. If i could send you the (TunerStudioAppDebug.txt) file you can see it?
Re: Protocol Error
joseedgardosanchez wrote:Hi, I have similar problem with the difference that i have Egt can box and lost the communication with the egt box. If i could send you the (TunerStudioAppDebug.txt) file you can see it?
Re: Protocol Error
Try to run the port scanner: http://forum.jbperf.com/viewtopic.php?f=2&t=1282. If you see the CAN-EGT listed then your issue might be a TunerStudio issue. If you don't see it listed then it is something else related to the ECU, the CAN bus or the CAN-EGT.
