Run two instances on one vehicle?
ErnieJones
Post by ErnieJones »
Hi!
I have registered Tuner Studio and so it's on both my desktop and my netbook. The only way I can connect to the ECU is through BlueTooth. Is it possible to have both computers connected to the ECU with Tuner Studio at the same time?
Also, if I leave the boot load jumper installed I seemed to have a hard time connecting. I started to think maybe this is a safety feature or was it just a bad connection?
Thanks you;
Ernie
slow_hemi6
Re: Run two instances on one vehicle?
Post by slow_hemi6 »
Boot jumper is only to be installed when upgrading from certain firmwares or in the case of reloading new over a corrupted firmware. Otherwise it is not to be connected/jumped.
ErnieJones
Thanks!
Any idea on whether I can have two computers running TS on the same vehicle?
Thanks you;
Ernie
slow_hemi6
I very much doubt it is possible. The blue tooth device should only "pair" with one other device.
DaveEFI
Post by DaveEFI »
ErnieJones wrote:Thanks!
Don't think so - but easy to copy the current tune into the correct project directory? If you do this frequently, put a short cut to it on each of the computer's desktops. I do this with log files so I can view more easily on a bigger monitor.
LT401Vette
Post by LT401Vette »
Only 1 device can talk to the MegaSquirt at a time.
