Hello,
I use Tuner Studio Version V2.6.05 on Megasquirt MS3 with MS3X.
I have a problem with the closed loop idle setting (I use a valve with 2 wire).
The problem is that the valve opens when slowing down at all engine speeds set in the settings.
Below settings screen captures.
Closed loop idle setting:
MegaLogWiever screenshots:
The valve opens when RPM word is 3,800 rpm
The time between TPS <1% and the valve opening is 3.3 second
Can you help me?
Thank you in advance
Problem with the closed loop idle setting
Re: Problem with the closed loop idle setting
First thing that springs to mind is the firmware you are running looks to be old, 1.2 or so. Current firmware is 1.3.2, any reason you can't upgrade?
http://web.aanet.com.au/arran
