AFR Table RPM Values
Hi, probably a dumb question but...how do I change the scale of the RPM values in the AFR table?
In my case a more proper skew would be 1450 to 13000
Thanks you;
Ernie
Ernie
Re: AFR Table RPM Values
Just click on the numbers and change them.
I tried that but it did not seem to work. The bike was running at 1500 (or so) and I changed the first column to 1500 and the highlights were still on the other column. Oh the joys of learning new software
Thanks you;
Ernie
Ernie
The one you clicked on changed, right?
Now if you still had others with lower values between, then the table can track in odd ways. Change all the bins to the RPMs you want, then try it.
Thanks, that worked
I went into the timing table and it seems you can't make a column higher then 9,000 ? Same thing with the VE table?
Thanks you;
Ernie
Ernie
Check under:ErnieJones wrote:Thanks, that worked
Basic/Load Settings --> Gauge and Settings Limits
That is where you can change the Max RPM.
I've got those dialed up to 14,000 but I'm not talking about the gages (which read correctly) I'm talking about the Spark & VE Table. They seem to be limited to no more then 9,000 RPM which really sucks as in my case I typically spend hours above 10K as a cruising RPM...and above.LT401Vette wrote:Check under:ErnieJones wrote:I went into the timing table and it seems you can't make a column higher then 9,000 ? Same thing with the VE table?
Thanks you;
Ernie
Ernie
Well that's just weird. When I went to verify that I had set my top speed to 14k (and it was) when I went back out I could then choose an RPM higher then 9K.
So problem solved, but in a strange way So thanks, I guess!
Thanks you;
Ernie
Ernie
