I have problem to view the help pages on my pc running ubuntu 14.04.
If I open up any window, e.g. Rev limiter and select the help menu, a new window is opened up with the help pages but all the pages are blank. If I use another pc running window 7 it all works fine. Do I need some kind of viewer to read the help files?
/rikard
Blank help pages on Ubuntu 14.04
Re: Blank help pages on Ubuntu 14.04
The release of the pdf viewer TS is using has dependencies on the sun/oracle JRE for image rendering.
So currently you need to use the sun / oracle JRE or images will not appear.
There is supposed to be an update coming when removes this dependency, so I am expecting this to be gone for the next major release of TS.
Thanks Phil. I will give it a go with the Oracle JRE.
/rikard
/rikard
