I'm trying to do two things right now: first, to incorporate this formula as an output channel:
Code: Select all
myspeed = { 3600 * timer_clock1 / ( pwm1_16 * 39898 * timer_pre_val1 ) }
Second, I want to clean up the 'garbage' values in the TIOx Programmable Output fields; I've tried just entering zero or 100, but every time I reopen the project, they're back to garbage. I've tried to load a fresh IOx .msq from Jean's site, but it loaded into the uSM. No errors were thrown, but not much happened either (again, MS2 devices don't include ADC9 as an option from which to input a signal).
I've attached the project .zip file. I'm definitely missing something, here ...
