I took some datalogs trying to diagnose a starting issue, can't seem to find the Voltage in it. Does TS log Voltage level?? Is there an option that I'm missing? I could have sworn I had that in logs a few years ago last time I was messing w/ stuff. Thanks.
Logs in question are attached to this post:
http://www.msextra.com/forums/viewtopic ... 54#p421476
Not seeing voltage in data log
Re: Not seeing voltage in data log
What gets logged is defined in the ini.
The standard MS1 release 29y4 for many years now, does log battery voltage as "batt V", but it appears the older version 29v that you are using quite possibly does not.
You could add it using a custom.ini file, or update to the stable release 29y4.
Hmm... 029v was superceded in February 2007.
yeah it's prob been that long since I last messed with it. Don't even remember how to update it anymore. And kind of afraid to update since it's my daily driver now.. lol. I'll have to look into it. Thanks for the tip about the ini, I should be able to add that.
