I have a ms1 2.2, with an innovate lc1. the problem I am having is. afr gauge is reading correctly, afr gauge on tuner studios dash board reads correctly, but when I go in to the auto tune it says o2 out of range. and reads dead rich. I have been searching and trying to figure this out for the last 9 hours. Thanks for any help!
I will try to figure out how to attach a datalog in a minute.
new and confused. o2 out of range
Re: new and confused. o2 out of range
cant figure out the data log, but did figure out the o2 issue. I wired it up according to the instructions that were supplied with the LC-1. Swapped the yellow and brown outputs on the controller to the ms1, changed the settings so the ms would recognize the LC-1, and all is well!
