I have issues running the GPS dongle set at bluetooth. Apparently for some reasons TS doesn't want to connect to the ecu, although everything is fine. So far deleting the paired GPS out of the laptop was the only way to regain connection.
Ideas ?
TS making not connection with ECU with GPS bluetooth on
Re: TS making not connection with ECU with GPS bluetooth on
So is the GPS connecting fine, but then the ECU doesn't?
Both using Virtual Com Bluetooth?
No, ecu is on usb through a Serial/usb converter.LT401Vette wrote:So is the GPS connecting fine, but then the ECU doesn't?
Ok, that is odd...
GPS on Bluetooth, ECU on USB. The ECU connects if the GPS isn't present, but not if it is?
Can you post / send the TunerStudioAppDebug.txt?
How do I do that ?LT401Vette wrote:Ok, that is odd...
It will be in your TunerStudioProjects dir.
If it is too big to post, email it to support at efianalytics. com
OK, sent by email.LT401Vette wrote:It will be in your TunerStudioProjects dir.
