I am using Daytona wide band, the gauge is showing different numbers than the ones reflected in the software (Tuner Studio). The difference is like 0.3 ~ 0.5.
please guide me.
Note; I am using 0 v = 10 : 5 v = 20
Daytona wideband reading accuracy
Re: Daytona wideband reading accuracy
Does the heavy heater ground go to the engine block/head ground point and the small sensor ground go to the MS's sensor ground point?
both grounds are connected to the block.
The sensor ground should go to the MS. The heater ground can stay on the block.odd boy wrote:both grounds are connected to the block.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
