Read the manual and help files and all the EGO fields to fill in are giving me that deer in the headlight look.
I have an LC-1 with Bosch sensor.
Can I get a helping hand or tutorial please?
EGO - LC-1 setup
Re: EGO - LC-1 setup
Please let us know what firmware you're using first. The procedure will depend on what firmware variant you have.
oops, sorry.
MS2/extra 3.3.3
Tuner studio 2.6.04
MS2/extra 3.3.3
Tuner studio 2.6.04
Go to Tools -> Calibrate AFR Table
Select Innovate LC-1 Default
Click "Write to Controller"
So... I ignore the Fuel settings/EGO Control section IF a known controller is chosen?
That is the calibration part. What fields in the EGO control screen are giving you trouble? Have you seen the notes here:
http://www.msextra.com/doc/pdf/html/Meg ... .3-90.html
Like other sections it is written by someone that already knows the drill. It basically gives the title of each field with little clue as to what to do with it.
I need further/deeper explanation of what I am supposed to do with each field as well as when and why.
