Do you mean you updated the JRE from 1.8_25 to 1.8_31?FYI Java just updated my 64 bit machine from 8.25 to 8.31.
That won't matter on Windows, with 2.6.12, it will use the JRE bundled with it.
I don't believe that is the case, these releases are patch releases with very few changes. All real development is in a whole different branch.After all this something has to have gone awry with the communication code since the earlier TS versions.
If you are having crashing problems, you should not be using Detect. It will open the ports that cause a crash. Also Detect sometimes has issues with bluetooth due to the lengthy port open times.No way to know about the JSSC or any other as the Detect port isn't working. Is that a clue?
