I was going thru the manual for tuner studio. Nice job!
A possible upgrade in section 9.14. There is wording for the positive and negative % that says the effect is the same, to add fuel to that cylinder or channel. I would think (+) adds and that (-) takes away.
tuner studio manual section 9.14
1970 Chevelle, 540 big block, AFR heads, headers, mild cam
MS3 release 1.4.0, sequential fuel, LS2 coil per plug
Tuner Studio MS V3.0.05
Re: tuner studio manual section 9.14
Yes, James has done a great job with all the new Manuals.
That does look to be a bit of an error.
9.14 Injector Trim Tables
The InjectorTrim Tables allow you to specify a percentage multiplier for adjustment on the basic fuel pulsewidth
to allow for difference per cylinder.
• 0% means no adjustment
• Positive numbers mean to add fuel to that cylinder or channel
• Negative numbers mean to add fuel to that cylinder or channel
