Error on adding fuel pressure gauge
jb007
Post by jb007 »
Hi.
I get the following error on loading TS v2.6.14:
Code: Select all
1 Errors:
Error: Variable 'adc6' used in expression, but not defined as OutputChannel or Setting Parameter in Mini MS3 No Fuel, Problem at:
[custom.ini]:[Line:2]:      fuelSensorVoltage = { adc6 * 0.0048876 }
My Custom.ini is:
Code: Select all
[OutputChannels]
     ; No use 0psi=.5v 30psi=4.5v to calculate pressure from voltage
     fuelPressure = { fuelSensorVoltage  > 0 ? (fuelSensorVoltage  - 0.5) / 0.1333333  : 0 }
[Datalog]
     entry = fuelPressure ,             "Fuel Pressure",         int,    "%d"
I'm running a 30PSI sender 0PSI=0.5V 30PSI=4.5V
I've created the gauge and the 'fuelPressure' variable is there. What am I doing wrong?
Jim
1968 Australian Morris Mini fitted with a 1310cc A+ engine
14point7 WB, TunerStudio MS Ultra & MegaLogViewer HD
My Blog: http://www.jims-blog.com
Re: Error on adding fuel pressure gauge
Post by LT401Vette »
What firmware are you using?
Basically it is saying that there is no OutputChannel 'adc6' defined in your firmwares ini file. You likely are using the wrong ADC OutputChannel for your firmware.
