RTC inside the logs?
eMTea
Post by eMTea »
Should the RTC (I have one installed)be a part of the log?
I'm looking for a way to easier sync the logs with video in race renderer.
-MS3X, (V3 PCB) 1.2 RC 1 firmware. Controlling a light modified Audi 1.8TQ AEB 20v engine with Holset HE221W turbo, 299.4 HP and 400Nm at the hubs in Dynapack.
Re: RTC inside the logs?
Post by jsmcortina »
Which logs?
For SDcard datalog, the date and time are recorded at the start of each datalog and then the number of processor (not RTCC) timer ticks are recorded on each block of data. I have not tested to see if there is any skew between these two clock sources. It would be possible to interleave RTCC information within the SDcard logs (say at 1 or 10 second intervals?) but this is not presently done.
TunerStudio could theoretically generate the date/time for each record it extracts based on that data.
Moving this topic to the TS section so Phil can offer his thoughts.
eMTea
Post by eMTea »
I'm looking for a way to be able to use a 1hr log, and be able to sync a 5min video at the correct spot.
It doesn't need to be spot on, but in the ballpark.
LT401Vette
Post by LT401Vette »
It seems it would be quite possible to include the Date/Time stamp in the log in a future release.
Either just in the log header or as a running field.
eMTea
Post by eMTea »
It would be great! Easier to chop out the part of the log that belongs to a certain video clip would make things a lot easier :)
dll67
Post by dll67 »
Any progress on a RTCC running field .. I would like to use time instead of clock ticks in megalogviewer hd as well as have a clock on the dash
MS3PU/IOx/CAN-EGT/DBWx2 540ci BBC 325cc int runners (2)innovate LC2 wbo2's, Hilborn ITB injector cnvrtd to EFI, 55LB Inj, d585 coil near plg, 60-2 trg whl & cam ph snsr, Muncie 4spd w/10T VSS, Tilton 7.25" cerametalic cltch 8.5LB flywhl
LT401Vette
Unfortunately I think this fell off the radar.
dll67
Post by dll67 »
LT401Vette wrote:Unfortunately I think this fell off the radar.
In this post James and Reverant talk about getting the RTCC data through CAN
http://www.msextra.com/forums/viewtopic ... ilit=clock
It sounds like a ini modification to add a channel to datax is possible?
From there it would just be a guage on the dashboard directed to that channel.
I think MS Labs/Reverant did that in this video
https://www.youtube.com/watch?v=gJgNOnfLkL4
