yeah they are pushing ads and amazon products in ubuntu... u can remove/disable all of that ****.
If you think that windows 7 on a single atom is fast enough, then arch will fly.
lol I boot ubuntu under 15 sec and it's quite bloated with apps and startup services... ssd, i7 quad core etc
that's why I still run the lts as daily driven if pc is powerful enough. (but I have arch and windows in other partitions too).
I agree that on slower cpus and hdd ubuntu is no go. Better using lighter DE like LXDE or Xfce and start removing unneeded services and bloat.
You can have much lighter system while looking equally good if you know how.
First try the default os on raspy2 and make it run on it, it could be enough for you and could be a needed step.
Then make another sd card for Arch . It will be much faster if you build it light. You'll learn linux faster and the hard way (it could be harder on gentoo
Arch documentation is best one ever.
I have a very old single core non pae Pentium M 1 GHz ulv laptop, running arch and very very slow HDD. It fully boots at around 40 seconds using full lxde,can watch youtube, browse on latest firefox etc like it's a newer pc.
For comparison a fresh win xp loaded with same tools booted on it over 2.5minutes!
Also the raspberry images are prebuilt, so you don't start really from zero, card is already partitioned and arch alredy installed.
you still gets only command line interface so make sure to have the wiki and docs handy and know what to install, what is light and what not etc
Be careful about what you do or you'll broke it quite frequently
It's considered bleeding edge.
This will be your new home
https://wiki.archlinux.org/
This is an usual arch installation procedure on x86/x64 pc, just to get the command line, then you still have to go through the links at the end of the page, create users/permissions, install de/wm/apps etc :
https://wiki.archlinux.org/index.php/Beginners%27_guide
Arch compared to other distros:
https://wiki.archlinux.org/index.php/Ar ... tributions
Arch linux for raspy2 is here:
http://archlinuxarm.org/platforms/armv7 ... berry-pi-2
install then follow the regular arch wiki.
Also, be SUPER careful at disc names (sdx) when formatting discs or when using dd or when chrooting, you must be really sure you don't target your host disk or partition
You'll need quite a bit of spare time and lots of googling to grasp all of it, if you don't have previous linux experiences.
I have a raspberry1 b+, may try arch on it. Never tried on raspberrys, always on pc.
I see guys tried it with raspbian, I'd like to try tunerstudio without desktop environment, just with openbox or similar, before buying the new raspy.
Will report about this.
BTW raspberry2 boots 5 seconds faster than v1 already before the arch login prompt.
https://www.youtube.com/watch?v=aBOqOC6URk0
