I've entered the engine and injector size at the bottom of the Engine settings page. What else needs entered for the cc/min fuel flow gauge to work? Do I need to mod the INI file.
Thanks Ryan
cc/min gauge fuel flow
Re: cc/min gauge fuel flow
I'm dumb... I found the other dialog box I missed under DataLogging - Performance Economy. haaa
don't worry - it took me awhile too. even started modifying the ini before I got to that realization!
1990 Nissan 240sx / SOHC KA-T / DIYPNP
You can also go into designer mode and change the min/max values and the amount of decimal places. The motors I'm running only use 28ish cc/min at WOT and around 15 at cruising rpm/load. I'm going to double check the reported values using a scale and such once the engine is up on the dyno.
