I purchased Jean's Tiny I/Ox and was able to get it loaded into TS and communicating through my MS3 to get the firmware loaded. I hooked up a sensor but couldn't get TS to read the sensor. The data just wasn't updating. So i started playing around with the CAN-bus device settings. Under CAN parameters I moved the 'my can ID' to 4 thinking thats what it needed for the Tiny I/Ox. After I did that my ms3 no longer communicates with TS. I have provided the error screen shots below along with my MSQ.
Any ideas on how to fix this?
I have tried:
-Disableing CAN broadcasting in project properties
-Deleting the TinyI/Ox in project properties
-Reloading the firm ware to my MS3
I'm at a loss of what else to try.
thanks, Kyle
MS3 communication errors with Tiny I/Ox CAN
Re: MS3 communication errors with Tiny I/Ox CAN
here is the app debug as well. I had to zip it to post it.
thanks
thanks
That would have changed the MS3's CAN ID to 4, while TunerStudio is still trying to talk to it on 0.I moved the 'my can ID' to 4 thinking thats what it needed for the Tiny I/Ox.
So change The TunerStudi Project to look for it on 4.
Open Project Properties (Press CTRL+P)
Click on the Can Devices Tab.
Set Main Controller CAN ID to 4.
Click Ok
That should get you back talking, then you probably want to put the MS3 back on 0 to avoid future confusion.
Also if your Tiny IOx is actually on 4 too, I would disconnect it until you get this squared away.
That worked Phil. Thank you for the quick reply!!!
