Tunerstudio V2.6.14 Windows 8.1 Pro Tablet Problem
Help please,
I bought a windows tablet so i can use Tunerstudio but i can't get it to connect to the ECU using bluetooth, i'm using a Socket bluetooth adapter which i can connect to using my windows 7 laptop fine. But when i add a bluetooth device on the tablet it finds it fine and pairs it ok but when you try to set it up in tunerstudio it doesn't find the bluetooth ECU and windows pops up wanting to add it again which then fails.
i'm not sure if this is a Tunerstudio issue or a windows issue.
Windows 8 will find my phone on bluetooth ok and add delete files from my phone so i guess the bluetooth module in the tablet works?
any suggestions ?
any suggestions ?
Re: Tunerstudio V2.6.14 Windows 8.1 Pro Tablet Problem
are you getting a Com Port for the BT Adapter when it pairs?
There is normally 2 set up, an incoming and an outgoing. You must use the outgoing.
yep i get com3 and com4, but it wont connect to either.
Also when i go to communication setting and just click detect using RS232 Serial (default) nothing, even trying all the options under USB & Wireless nothing either
Hmm,
Perhaps try using the S command from Mini-Term or TeraTerm.
Any chance there is any 3rd party bluetooth software installed? If you see anything like bluesoleil, that tends to break bluetooth.
Com4 is my outgoing, Com3 my incoming
When i try to connect using Teraterm on Com 4 it just says cant connect
Com3 it does nothing
Bluetooth Com ports should work on Windows 8, but there seems to be something wrong here.
It would seem like it might be your adapter, but if your Windows 7 computer can connect, then I dunno.
as an update i think i found the problem but no idea on the solution, if i delete the original bluetooth pairing and repair before starting tunerstudio then Tunerstudio connects and everything works fine. If i break the connection in anyway and try to reconnect it does not work until i delete the pairing again and start again.
So it's something to do with the pairing pin code being needed everytime, as when i do the same in Windows 7 it asks for the pin every time the connection is lost
It may be a bad BT Adapter then. You shouldn't need to reenter the PIN each time.So it's something to do with the pairing pin code being needed everytime, as when i do the same in Windows 7 it asks for the pin every time the connection is lost
ah but works fine with my phone thou which is the confusing part.
I am having the same issues. The Bluetooth adapter worked fine with my MacBook air until it died last week. New windows 8.1 laptop finds the adapter says it is working but then says it is not connected. No com port. Shadowdash on phone works perfectly. I have been running this for long time with my previous laptops.
been looking this weekend and it seems to be a pairing issue. On every restart the bluetooth unit i have wants the pin code sent but windows is not actually sending anything but if i delete the pairing and start again then it works again
Interesting though that power cycling doesn't effect Android.
It does seem like Windows has much more trouble dealing with Bluetooth than Andoid. But I am using BT Adapters with windows 8.1 here and don't have to repair after power cycle.
ah well that is interesting as i have used this with MSDroid on my phone and power cycling always requires the PIN code to be entered. Maybe my problem is caused by my Bluetooth adapter that i use??
That is what I would suspect.Maybe my problem is caused by my Bluetooth adapter that i use??
I have a similar issue with my bluetooth that i purchased from efi, it pairs fine and shows connected for about 1 second then just says paired. Can't seem to get it to say connected again.
Once paired, it will disconnect until some application such as TunerStudio tries to connect. Then the blue light will go solid.kortmeyer wrote:I have a similar issue with my bluetooth that i purchased from efi, it pairs fine and shows connected for about 1 second then just says paired. Can't seem to get it to say connected again.
