hi guys
I dont think that this is this just hystrises on updating the gauge as it always seems to be that bit out of step
the afr gauge is showing the correct value in the digital Box in the gauge
But the actual display of the gauge does not tie up and is out of step see picture
this picture was taken on the last but 1 release of TS as mine just updated to the latest version this morning.
the digital indication is correct and ties in with the fited stand alone wb gauge.
been looking thro the manuals but cant find anything that sort of covers this
I do like the auto tune now , the warmup worked realy well for us did 1 run from cold temp at 5C and car has been starting
on the button.
regards Bill
afr gauge mis match to digital reading in gauge
Re: afr gauge mis match to digital reading in gauge
There was a bug that threw off the needle position if the high or low limits were not integers.
This should be resolved in 2.6.14. So if you just updated to 2.6.14, check the gauge again.
The work around for it was to use whole number limits on the gauge.
thanks for reply I am currently using 2 .6 .16 the picture was from version before that one
and i belive i still have same problem i will check later in the week when i get hooked back up to the car
and it is running and let you know in mean time will check gauge limits
thanks bill
thanks bill
