Realtime Graphing?
Realtime Graphing?
I just got MS II v3.0 and have a question/suggestion about features in TunerStudio.
Having the ability to see gauges is nice and having a logger/viewer is good too. Being able to see a graph in real time is much more valuable as a diagnostic tool than only gauges or only an external log viewer (which plays recorded log files only). OBD-II laptop programs such as autoenguinity for example display and graph PID data in real time. As a DIY mechanic that's the best kind of diagnostic tool you could ask for.
Honestly, I don't care at all for the gauges. I would rather have a purely data view and real time graph. I'm just a data and diagnostics kind of guy. Just curious if this is perhaps an idea that's on the table, on the back burner, or can't/won't be done?
To be honest when I was checking out information on MegaSquirt I assumed that type of feature is what I was seeing when looking at promotional images of the log viewer. I thought the images were of a real time graphing part of the software. Perhaps that's my own fault for being so used to watching youtube videos of guys using autoenguinity laptop scan tools and picoscopes. Only until after I got the stimulator working and created a log did I find out it's only an external log viewer. Not that there is anything wrong with that it's just not as powerful of a diagnostic tool as a real time graph. Thanks for hearing me out and hope to eventually see that feature added to take MS to the next level.
or since I'm new here perhaps there is actually a feature in there for it and I simply haven't figured out how to turn it on yet?
Re: Realtime Graphing?
You can setup a gauge as histogramm, which is a real time graph?
fun is not a straight line
Sven
Sven
Guess that was a poor job of explaining what autoenginuity's diagnostic capability is. Here's a good example.
http://youtu.be/9l5B2IGtEdM?t=11m28s
Basically it's a Megalogger view but in real time. That's how technicians actually use scan tools to diagnose issues. Yes we have that capability but you have to record, then export to low viewer and then watch it, it's not in real time. Again I'm new so maybe there's a way to enable that kind of view in TunerStudio that I'm missing.
A couple points here...
You can trail a log file with MLV while it is being captured by TunerStudio. To do so start a data log in TunerStudio, then Open MLV and select:
File --> Trail Live File
In that mode MLV will continue to load the log as it is written.
Point 2 is a bit of a teaser for the upcoming TS.
This has an embedded Log Viewer that displays logs real time or loads logs.
Or this feature I like even more... The Tuning & Dyno Views. There is a GUI builder similar to the Dashboard designer, but You can add as many different Dashboards, Settings Panels, Tables or Curves as you want.
Stay Tuned (Pun intended)
Yes! That's exactly the kind of thing I was hoping to find. Only a tad inconvenient right now to have 2 separate programs. Hmm after looking I don't see any option for live trail in MegaLogViewer Lite 4.0.04 I'll assume I have to upgrade to the pro version to get that feature?
I only have the free lite version any idea if the live trail will be for free version (after integration)? Was planning on upgrading to pro in the future anyway. Thank you for the response and images.
Historically Graphing has been kept separate for a couple reasons, largely resources. TS was kept slim to run well on old slow laptops, this used to mean 90's built laptops. These days even if you have an 8 year old laptop, it still does have power.
However, the other reason is it isn't realistic to try to fit all analysis tools and features into the tuning app or you would create a confusing experience.
At this point there is no plans to have the embedded log viewer in the free version. We do need to eat hereI only have the free lite version any idea if the live trail will be for free version
Makes sense especially with the amount of data one might try to pull off from a bluetooth dongle using lower transfer speed than a cable (presumably). I haven't even purchased the harness to start this install but when I do for sure I'll upgrade to pro. I've been told I'll need the VE live tuner anyway which is only available in pro too.
Thank you for letting me know that MS does have the capability and progress is always being made in the software. Thank you, now I'm excited again.
THIS IS GOING BE AWESOME. Can't wait.
Phil, can you add an undo/redo button to that ve table in the dyno view?
Can't wait for the new version!
Mother of god... Can't wait! Nice work Phil!
Sven
Sven
Yes, along with a burn button.lagos wrote:Phil, can you add an undo/redo button to that ve table in the dyno view?
Oh I think you'll find this quite amusing after the whole topic I created for it lol. I was using a really old firmware version 2.0.1. Well I decided to go ahead and try to upgrade to 3.3.3 and what the hell a whole bunch of stuff changed in TunerStudio. Now I have options that weren't there before. Same exact TunerStudio as yesterday just a new firmware. Menu options that were not there. The best part is I almost cried tears of joy when I saw the real-time display option. It most definitely was not there in firmware 2.0.1. So if you have an old firmware on your unit then upgrade!!! If you're like omg why's he running such an old firmware? Again I just got the unit and the stim board, haven't even had it a week, it was a gift, and was running a really old firmware.
This is so cool. This is the view that I wanted. I LOVE the new features. Feels like I just got a massive free upgrade to a "semi-pro" version compared to the old firmware. This fan-f'ing-tastic!
Did the dyno view ever make it into tunerstudio?
Tuning and Dyno Views are in the upcoming 3.0 beta.
Cant wait, i visit 2 time in Dyno allready but want visit one time more before car go to painter.LT401Vette wrote:Tuning and Dyno Views are in the upcoming 3.0 beta.
Nice work Guys!
I like my Ms3+ms3x
https://www.facebook.com/PikkiS-112502032715453/
https://www.theniceman.com/coppermine/
Ford Taunus Coupe 1975 2.0i Turbo
Ms3 + MS3x in Taunus
MS3 Pro Ultimate in PikkiS
