Tuner Studio 3, new feature list?
Phil, you did let a few cats out of the bag in http://www.msextra.com/forums/viewtopic ... 22&t=57765, are there any other news official or otherwise in terms of added or changed features?
You know I would like to see MAF autotune. Another thing that would be interesting is a capability to connect to dyno control and logging systems for stuff like realtime BSFC display. I really don't know if the dynos support live data streams like that, but if they do it would be a good feature.
When will you start releasing public betas?
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: Tuner Studio 3, new feature list?
Actually, that post seems to have been TunerStudio 2.7. I think TunerStudio 3 will have even more awesomeness.
One thing I'd like to see is an integrated firmware loader.
I noticed 2.7 too, but I am pretty certain Phil said the next release will be 3.0. I vote in support of the integrated firmware loader.Matt Cramer wrote:Actually, that post seems to have been TunerStudio 2.7. I think TunerStudio 3 will have even more awesomeness.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Yes, that will be there, it is what I am currently working on.One thing I'd like to see is an integrated firmware loader.
some simple maf tools would be nice. eg the ability to select values, multiply, divide, copy and paste would make things so much easier
Looking at the screenshot, I think that has already been done. Notice the +, - and x buttons?
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
LT401Vette wrote:Yes, that will be there, it is what I am currently working on.One thing I'd like to see is an integrated firmware loader.
Any chances of a Lambda Delay Table tuning feature as mentioned in the past? That could be very helpful.
Thanks.
Thanks.
2 features very cool to add would the autotune of Accell enrich and time of injection angle
ashford wrote:some simple maf tools would be nice. eg the ability to select values, multiply, divide, copy and paste would make things so much easier
Nope. MAF not MAT. 3rd on the Poll, http://www.tunerstudio.com/index.php/co ... eaturepollsubwoofer wrote:Looking at the screenshot, I think that has already been done. Notice the +, - and x buttons?
With all probability all 2D tables use the same code (anything else would be silly design and a lot of work for no gain), so it is likely to be there. I just checked the current release, and there are no value manipulation buttons there. So by the looks of things, all 2D tables have now gained the manipulation tools we know from the 3D tables.Blown88GT wrote:Nope. MAF not MAT. 3rd on the Poll, http://www.tunerstudio.com/index.php/co ... eaturepollsubwoofer wrote:Looking at the screenshot, I think that has already been done. Notice the +, - and x buttons?
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
If it hasn't been mentioned I would like to see a Project "save as"
I really would like to have MAP as a trigger for SDCard logging so SDCard logging would start automatically when boost gets to a set point. Currently i can select between TPS and RPM, sometimes i rev high with only 10PSI (boost control is deactivated), and then i dont need a log. I just would like to have a log when i get a "Dangerous" Boost, like 25PSI or so.
Greets
Greets
Bumping this back to the top of the stack, have you got any news for us, Phil? What did you present at MegaMeet?
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
I noticed in version 2.6.19 (with a MS2) that when you set your project settings to use Lambda instead of AFR. That under the menu Accel Enrich -> Time-Based Accel Enrichment the live graph still shows AFR next to TPSdot and MAPdot. It would be nice that this would also reflect your project settings.
Thanks!
Thanks!
Car: Renault Clio RS 172 2.0 16v N/A (182 RS exhaust manifold, 200 cel race cat., KTEC silent stealth exhaust, lightweight flywheel, QUAIFE differential)
ECU: MS2Extra v3.0 with firmware v3.4.0
Lambda: Innovate LC-2
This. It's kind of annoying trying to remember where my project is actually saved when I keep loading new firmware.Fueler wrote:If it hasn't been mentioned I would like to see a Project "save as"
The Ratchet RX7
1988 RX7 powered by 12V VR6
Ms3x, ID1000's, e85, pt6266, NX wet kit.
Stock block w/ arp hardware
TH400
8.8 IRS
TH400
8.8 IRS
It's always under My Documents/TunerStudioProjects.papiogxl wrote:This. It's kind of annoying trying to remember where my project is actually saved when I keep loading new firmware.Fueler wrote:If it hasn't been mentioned I would like to see a Project "save as"
File --> Project --> Export Project Archivepapiogxl wrote:This. It's kind of annoying trying to remember where my project is actually saved when I keep loading new firmware.Fueler wrote:If it hasn't been mentioned I would like to see a Project "save as"
That has been changed for TS 3.0 to:
File --> Project --> Save Car Project to File
When is tuner studio 3 expected release date?
Shooting for beta release in Dec
