Bought a new laptop yesterday replacing my broken laptop that I used with Tuner Studio, Tuner Studio would not accept registration, said I used up all 3 allowed. Over the last 3 years I've upgraded laptops several times, Tuner Studio and personal info uninstalled & wiped before disposing of. I am only tuning one Megasquirt, since Tuner Studio is no longer being used on prior laptops, I would hope license could be transferred to new laptop.
Thanks,
Tuner Studio & Megalog - Do I need to purchase new License?
Re: Tuner Studio & Megalog - Do I need to purchase new Licen
the licence is for 1 user on up to 3 devices at a time, supposedly if a computer does not connect for x amount of time it gets wiped from your device list. a quick email to efi support and they may be able to bump a device off your list for you.
Yes, laptops not used will roll off the count if not used for 30-60 days.
If you need to urge one off the count sooner contact support <at> efianalytics. com
So if you registered 2 laptops and the 1 laptop is broken and doesn't work
it'll go back to having 2 more codes?
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
Yes.M30guy wrote:So if you registered 2 laptops and the 1 laptop is broken and doesn't work
grom_e30 wrote:the licence is for 1 user on up to 3 devices at a time, supposedly if a computer does not connect for x amount of time it gets wiped from your device list. a quick email to efi support and they may be able to bump a device off your list for you.
Thanks for explaining the license issue.
Thanks Phil, after grom_e30 explained, I sent a message to efianalytics, my new laptop is now registered. Keep up the awesome work.LT401Vette wrote:Yes, laptops not used will roll off the count if not used for 30-60 days.
