Tried several downloads and installs. It fails on installation with the message that setup files are corrupt.
Only receiving 54.4 mb if that means anything.
TS download 2.6.19 failing
Re: TS download 2.6.19 failing
Hmmm, I just downloaded the one from tunerstudio.com it ran fine.
Is it failing on during the install wizard, or failing to even launch the installation wizard?
54.4 MB sounds like the whole file. Is the digital certificate in tack when you look at properties?
What OS are you on?
What OS are you on?
just had the auto update fail went to install and got something about a jarfile missing or corrupt on a win xp computer, my win7 worked fine though
Win7. Tried 2 computers. 1 near new and an old tired laptop. Same thing.LT401Vette wrote:Hmmm, I just downloaded the one from tunerstudio.com it ran fine.
What OS are you on?
Just for drill I tried installing a program from a different company. No problem.
I first get the MS screen and about certificates which is unknown. Hit run and then get the corrupt setup files message.
FWIW Megalog HD updated itself just fine.
If there is no cert, the download must have become corrupt.I first get the MS screen and about certificates which is unknown. Hit run and then get the corrupt setup files message.
Try downloading it again, you may need to clear your cache or use a different browser.
I cleaned out everything on the new computer and deliberately left the old laptop alone.
Download another copy of TS and ML
Installed normally on both computers.
Oh, well. Whatever it was or wasn't they are now installed.
I have been having the exact same problem..
Using Chrome on win 7 (Even after cleaning out everything)
Switched to IE8, worked first time
Gordon
Gordon
