My customer is logging a second frequency-based MAF through the IOx. The bus frequency is 24MHz with prescale and divider of 1. The frequency is thus 24,000,000 / canpwmin0, where canpwmin0 is the number of clock 'ticks' between MAF pulses. Simple so far, right? (It took a few tries before Jean's explanation sunk in ... )
The problem comes in when I try to set up the custom .ini to use this value in the MS3. At Jean's suggestion, I've set up the following:
Code: Select all
[OutputChannels]
MAF2 = 24000000 / canpwmin0 ;
; establish the frequency from the IOx, source = Bus (24MHz), prescale and divider are both '1'.
What's odd is that it gives TWO errors for the same line, when I don't see anything wrong.Error: Malformed [OutputChannel] entry, Problem at:
[custom.ini]:[Line:11]: MAF2 = 24000000 / canpwmin0 ;
The other thing I'm trying to set up are indicators based on outputs TO the IOx; for example, I want an On/Off indicator showing when CANOUT1 goes high, declaring that the sump valve is open. I've found canout1_8, and I've found how to define an indicator as
but what I DON'T see is how to use that expression to actually set up an indicator.indicator = { canout1_8 & 1 }, "Sump Closed", "Sump OPEN", white, black, red, black
A little help, please?
