Good day. i curently havre a MS1 set up for a 7 pin hei module. Unable to datalog tooth count. Keep getting a pop up stating :
Unable to start loging
Reported Error:
Please Enable the LOGPAGES setting in Project Properties
Been at it for 2 days now. any help will be appreciated. Thanks
Unable to datalog with tooth logger
Re: Unable to datalog with tooth logger
Open Project Properties. From the main menu:
File --> Projects --> Project Properties
or press CTRL+P
On the Settings tab you will see the LOGPAGES setting. Enable that. Click Ok.
or press CTRL+P
What version firmware are you using?
MSnS 024s
I believe that firmware is too old. It doesn't support the trigger or tooth logger.
Update to the much newer (but still a good 8 years old) 29y4 and you will have tooth loggers
