Possible 3D View rendering issue?
I was checking out a user's msq earlier, and noticed that as I rotated the 3D view around, it appeared that the blue/green cells appeared over the redder ones even though the redder cells should have been in front. See the two attachments... table 1 appears normal, but then rotate the 3D map so that you're looking in from the higher load areas, and the bottom lower VE table cells appear over the middle of the VE map. MSQ where I noticed this is also attached.
TS 2.6.141990 Nissan 240sx / SOHC KA-T / DIYPNP
Re: Possible 3D View rendering issue?
Anyone confirm? Problem with my install or is this a TS issue?
I'm not trying to complain/nitpick, but simply want to report minor issues (if it isn't related to my specific install) that could hopefully get rolled into a future TS as time permits... is this the preferred approach for noting and reporting minor issues? I realize I'm not necessarily asking for help, but I also don't know if I should be looking to fix my specific machine without any confirmation.
It does that.
roger, thanks PhilLT401Vette wrote:It does that.
