ts wont exit
grom_e30
ts wont exit
Post by grom_e30 »
just recently ts does not always close down i have to go in to task manager and manually stop the process javw.exe in order to get it to exit, on windows 7 x64.
Brian H EFI
Re: ts wont exit
Post by Brian H EFI »
Please post your TunerStudioAppDebug.txt file form your TunerStudioProjects folder and I will take a look for you.
grom_e30
Re: ts wont exit
Post by grom_e30 »
it was to big to post so made a fresh one with it opening and closing ok and then having to manually close it
Brian H EFI
Re: ts wont exit
Unfortunately I am not seeing any clues in the log file.
It sounds like this is easily repeated can you give me a run down of what it is that you are doing before you have to kill the process?
grom_e30
Re: ts wont exit
Post by grom_e30 »
when i did the log file the computer had been restarted so i clicked on the ts icon and it opened up to the welcome screen where you can select a project, clicked the x the program closed down as expected the second time it did the same, after that i opened a msq in a temp project clicked the x and have the message ts is closing down as normal but the program just hangs there and cpu usage increases. from memory it usually hangs after opening a project and after it hangs the first time it repeats even if you don't open a project.
Brian H EFI
Re: ts wont exit
What if you open an example project or create a new project and just pick a firmware from the list and finish creating it , do you get farther or does it freeze up about the same place ?
Also could you please post the .msq that you are using to load as a temp project ?
grom_e30
Re: ts wont exit
Post by grom_e30 »
wonder if its related to this? it closes down on its own now though.
Brian H EFI
Re: ts wont exit
Did you install TunerStudio_v2.6.19 or update to it ?
grom_e30
Re: ts wont exit
Post by grom_e30 »
pretty sure it was updated from an earlier version
Brian H EFI
Re: ts wont exit
Go to the following directory and delete or move the tsUser.properties file from your user account folder then try running the installer and see if that fixes the issue.
C:\Users\Your PC User Account Name
http://tunerstudio.com/index.php/downloads
