Weird one
Weird one
In programmable I/O dropdowns, when using the arrow key to scroll through the list of selectable conditions, it won't scroll up past idle_cor_advance and idleDC, it'll just keep bouncing back and forth between those two. I can scroll down past them just not up, only when using the arrow keys.
Re: Weird one
Quite strange, I can't imagine what would cause that.
I'll have to have a look.
Re: Weird one
Sure enough! Quite reproducible too.......
Seems to only happen when scrolling up. If you select the next item (iacstep) above and pull the list down again you can once again scroll to the top of the list with the up arrow key.
EDIT: v.2.6.19 fwiw
EDIT: v.2.6.19 fwiw
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Re: Weird one
OK, its not just me. Phil, are you able to reproduce as well?
Re: Weird one
I guess that wasn't clear above, it is quite reproducible.
