Hi Phil
I'm playing with CAN bus for the first time - trying to run MShift through my MS-2.
Based on Lance's comments here http://www.msgpio.com/forums/viewtopic. ... 5481#p5477 it seems TS also gets confused a bit (ie not just me )
CAN confusion
CAN confusion
Kind regards
Philip
Philip
Re: CAN confusion
Jean has looked into this before. The problem was the MShift ini file not using the correct command to fetch the serial signature. TunerStudio is just doing what it is told.
Consider using the Microsquirt trans firmware as it doesn't have this problem.
Re: CAN confusion
Thanks James, would this have an impact on my physical build of the MShift hardware?jsmcortina wrote: Consider using the Microsquirt trans firmware as it doesn't have this problem.
Kind regards
Philip
Philip
Re: CAN confusion
The firmware is intended to use the same i/o pins as the MShift instructions - provided your trans is on the supported list. Feel free to download the firmware and manuals.Philip Lochner wrote:Thanks James, would this have an impact on my physical build of the MShift hardware?jsmcortina wrote: Consider using the Microsquirt trans firmware as it doesn't have this problem.
http://www.msextra.com/product-range/ex ... n-control/
