I don't think this is a big deal but the Input 2 indicator on TS does not change as conditions for that input change. In my case it just stays low. I put a "Manual Gear" gauge on my dash and that shows the correct gear being selected and Input 1 and Input 3 indicator shows the correct conditions but not Input2.
Not sure if this is a TS or ini or Mshift issue. I'm running the latest Mshift code and I'm connected via serial cable to Mshift.
MShift: IN2 indicator on TS does not change
Kind regards
Philip
Philip
Re: MShift: IN2 indicator on TS does not change
It sounds like an MShift issue or possibly the MShift ini.
To TS an indicator is an box that has an expression assigned. It the expression is false, it is off; if the expression is not false it is on.
Phil
When I select gears, the MANUAL gear indicator shows the correct gear which means that
1) TRansstim is sending the correct conditions
2) MShift reads them correctly
3) reports the correct gear to TS via the serial port
4) TS manual gear gauge displays is correctly
5) but the input2 indicator does not as it does not change at all, despite the correct manual gear being displayed.
Its not a major issue for me, I just wanted to report it FWIW. My guess is that its an ini issue but I know too little of the ini contents to go fiddle there.
Kind regards
Philip
Philip
