windows 10 compatible
is tuner studio and megalog viewer windows 10 compatible? I want to know before I upgrade my tuning computer.
Re: windows 10 compatible
Im just stepping here with no knowledge whatsoever. My guess is that tunerstudio wont have any kind of problems. What I think is going to be the issue, if there are any, is usb to serial converter compatibility.
Nope, no problem. I have been using Windows 10 for months.
MUCH better than Full Screen 8.
I held most of my computers on 7, but like windows 10.
Windows 10 and tunerstudio works perfectly for me. A side issue with very recent screens is the 4k resolution and Java not scaling well, select 'windows' as the theme and it works pretty perfectly,
