Liters/hr info TunerStudio
Hi, do any of you know if there is a way for me to get a gauge for L/hr in tunerstudio and/or msdroid/shadowdashms?
I am putting my ms3-pro in my boat and would like to know how much fuel is being consumed.
All input is greatly appreciated!
Re: Liters/hr info TunerStudio
In TS if you right click on the gauge, under "Trip / Economy" there are fuel flow gauges for:
- cc/minute
- Gallons/Hr
- Lb/hr
a L/hr could be added with a custom.ini
Rename the attached file to custom.ini and place it in the dir:
[TunerStudioProjects]/[YourProjectDir]/projectCfg/
Then when you reload the project there will be a LiterHour Gauge in the right click menu.
- cc/minute
- Gallons/Hr
- Lb/hr
Hi, thanks!
I tried it and it gives me the following error;
1 Errors:
Error: Variable 'gaugeFuelFlowLbHr' used in expression, but not defined as OutputChannel or Setting Parameter in MyCar, Problem at:
[custom.ini]:[Line:8]: tsFuelFlowLtph = { gaugeFuelFlowLbHr * 0.63 }, "lt/hr"
1 Errors:
oops, copy/paste mistake..
Try the attached.
Try the attached.
Now I'm getting this message;
1 Errors:
Error: Variable 'tsFuelFlow' used in expression, but not defined as OutputChannel or Setting Parameter in project, Problem at:
[custom.ini]:[Line:8]: tsFuelFlowLtph = { tsFuelFlow * 0.06 }, "lt/hr"
1 Errors:
Are you using the Registered TunerStudio?
tsFuelFlow does not exist in the unregistered edition.
Just got it upgraded. I'll try it again.
I redownloaded the code you wrote. It worked like a charm.
Thanks bro!
Thanks bro!
