I trying solve my problem with GPS logging and TunerStudio. I´m using GPS 818Xt which is working fine with RaceChrono.
GPS is connect via bluetooth
Performance and economy fields – filled
Communications:
Data rate 15 per sec
GPS config – COM7, baud rate 115200
Firstly I connect GPS, after that I start TunerStudion – on GPS Sattelites gauge I could see 9 satelites are there. I start data logging and runing with car – speedo no working, economy fields – nothing, HP gauge – nothing
Pls see attached log file
Where I could do mistake?
Thx for any help.
Regards,
Petr
818XT GPS logging problem
Re: 818XT GPS logging problem
In the log I am seeing a Satellite count, but all other GPS fields seem dead.
Is it getting a fix?
What version of TunerStudio are you using?
thank you for reply.
Yes, GPS is fix - I try it for many time, but result is stil the same When I´m using GPS with Racechrono, everything is ok. I tried use GPS via bluetooth and few times via cable directly, but result is the same... last year it was working a few times, but only a short time.
Tunerstudio version - I have the last TunerStudio MS version 2.6.19 - it is registration version.
I would suggest you work directly with Brian at support <at> efianalytics. com
All should be working there.
