calibrating afr table
im wanting to calibrate the afr table under tools but its not lit up, how do i enable it?
Re: calibrating afr table
Are you certain that you have Calibrations, Un/locked, also under the Tools menu?Bagged83dime wrote:im wanting to calibrate the afr table under tools but its not lit up, how do i enable it?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
No i dont, thank you ill try that tonight
