TS starts using 100% cpu
So I'm running TS on a Macbook Air, and most of the time it runs fine. However, if it's been open for a while, it will often start running extremely sluggish, using 100% CPU, and eventually get unresponsive and have to be killed. I've only noticed this when it's offline, but then again I don't often leave the ignition on that long. Anyone experience the same? This is 2.0.4 on MacOS 10.7.5.
Re: TS starts using 100% cpu
It sounds like it is eating up memory and running out. A look at the TunerStudioAppDebug.txt would show that.
Why such an old version? 2.0.4 is from 6/2012This is 2.0.4
