retrieve tune from ms3x
She run off with the laptop. Now have a new one with fresh TS and MLV. Is there a way to retrieve the current project data from the MS3x in the car? BTW thanks for a great system and support infrastructure!!! Have 3 great track weekends under the belt running a 4.6 dohc. Just want to avoid starting over.
Re: retrieve tune from ms3x
Just connect.
If you get any popups make sure you use the tune from the ECU. Under no circumstances use the "TunerStudio version" or "Send to ECU"
Then "Save Tune As"
Then "Save Tune As"
Incredible in simplicity and it worked.....easiest problem ever solved but note with your warning about changing name, logging out, verifying tune offline, the going back to the routine of change, download, and race. It could have easily been a disaster, All the best!
