EGO voltage logging
linzerl
EGO voltage logging
Post by linzerl »
I am investigating a small mismatch in the voltage on the wire from the TechEdge Wideband controllor and what MS3 (1.3.4) reports the voltage. I am abt .1v out. The mismatch was a lot larger (0.3v) however interestingly reducing all the lag factors back to 100 helped.
I am able to set a gauge in TS to show Lamba Voltage (set Oxygen Sensor to Wideand Lambda and then connect a gauge to the "egov1" channel.
However I'd like to set this channel up so I can log it in Megalogviewer..and that's were I am stuck.
Any tips please?
Brian H EFI
Re: EGO voltage logging
Post by Brian H EFI »
I have attached a custom.ini file for you, once you fill in the outputChannel name and the field name you can use it to log ego sensor 1 volts.
Just open the file in a text editor and fill in the outputChannelName and the Logged Field Name then save the file and place it in the projectCfg folder in your project folder.
linzerl
Post by linzerl »
Awesome..worked.
Thanks Brian..
sheek
Post by sheek »
do i replace ourputchannelname with a name and logged field name?
i want to log o2 voltage as well but i keep getting an error
please explain for the coder impaired
Brian H EFI
The outputChannelName gets replaced with the variable name that you want to log and the Logged Field Name is just that Field`s label. So for example in MS2Extra_3.3.3 the ego volts variable name is "egoV" so you would replace outputChannelName with "egoV".
