hi
im constantly losing the connection bettwen the megasquirt and the Laptop,
i have tested 5 diferent types of RS232 cables, including the ATEN UC232a usb - rs232 converter,
on the manual reffers to electronic noise...
but on the bench, is the same problem.
someone can help me???
rs232 comunication problems
Re: rs232 comunication problems
USB is the most common problem, but not always the culprit. I have had instances where it was indeed the RS232 cable.
However, if it is dropping on the bench, it sounds like there is another issue.
If you can post / send a COM Debug log with the drops in it, I can see if there is an error occurring or if it is timeouts.
To get the COM Debug:
- Delete your TunerStudioAppDebug.txt
- Start TunerStudio
- Check "Communications --> Comm Debug Log"
- Open your Project, connect to your MegaSquirt
- Wait for at least 1 drop out
- Close TunerStudio
- Post / Send the TunerStudioAppDebug.txt
- Start TunerStudio
- Close TunerStudio
LT401Vette wrote:USB is the most common problem, but not always the culprit. I have had instances where it was indeed the RS232 cable.
- Start TunerStudio
- Close TunerStudio
tomorrow ill test it
there is the debug file
regards
regards
for now
problem solved
i have made a firmware upgrade and it seems to be good.
best regards
problem solved
best regards
