connecting through USB
Re: connecting through USB
With Brians, help updated firmware... but nothing changed
MS1, MSnS extra, PCB v 3.0, 029t
It looks like you are using an MS1 Extra project to try to connect.
Try creating a new project.
OK I will try that, but I need my old project as this is similar car and I want to use the same data for sturt up, so how should I do that?LT401Vette wrote:It looks like you are using an MS1 Extra project to try to connect.
Project -> New ProjectMaki wrote:OK I will try that, but I need my old project as this is similar car and I want to use the same data for sturt up, so how should I do that?LT401Vette wrote:Try creating a new project.
James I know how to start new project how to transfer all the settings to the new project?
Which settings?
ECU tuning settings will be fetched as soon as you connect or load up a MSQ you saved in the other project? Always be sure to regularly Save Tune As.
Project Properties - Settings will need re-selecting.
So I start new project and load the msq file from my old project? will there be no conflict as I saved my msq on the MSnS? and now loading to the MS2?
Project seems to have the wrong ini file selected. It's MS1 extra/029y3 and your ECU seems to be MS2 with a rather old extra firmware.
1993 Chevrolet Cavalier Z24
3400 Turbocharged Inter-cooled
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Ok guys, now I've tried starting new project, things look better through communications test now I get success but later I get this:
and here is the latest debug file attached
Just to let you know, the problem was in the cable. Bought new one and it works fine now. Thanks to all of you, especially to Brian.
now fighting the setting up of the MS2 as I was told that there is no way to copy paste setting from my MS1 project to MS2
